How to make the keyword "click" to increment every time it enters the interrupt module. Please see the code below and help me out. All the time "Click" remains 0.
2019-10-09 7:49 AM
#include <iostm8l.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <stdint.h>
#include <math.h>
#include "defs.h"
static int click = 0;
void delay(unsigned long dd)
unsigned long i;
for (i=0;i<dd;i++) nop();
void RTC(void)
unsigned long j = 0;
PE_ODR |= 0x80; // led indication for reset
if( click == 2) // reset module
click = 0;
PC_ODR &= ~(1<<3); //pc3 in place of push button - turn it off here
for(j = 0;j<20;j++)
delay(_250ms_); // 4.3 seconds in real
if(click == 1) // on module
click++;
PC_ODR &= ~(1<<3); //turn it off
for(j = 0;j<8;j++)
delay(_250ms_); // wait
if (click == 0) // off module
click++;
for(j = 0;j<8;j++)
PC_ODR |= (1<<3); // turn it on
for(j = 0;j<8;j++)
for(j = 0;j<8;j++)
RTC_ISR2=0x00; // clear interrupt flags
void SetupTimers(void)
CLK_CRTCR=0x04; // use iternal LSI/1 clock @ ~38KHz
RTC_WPR=0xCA;
RTC_WPR=0x53;
RTC_CR2=0x00; // disable wakeup timer for register update
while(!(RTC_ISR1 & 0x04));
RTC_CR1=0x04; // set 1hz clk
RTC_WUTRH=0x00; // change here for time change
RTC_WUTRL=0x78; //2 min timer
RTC_CR3=0x00;
RTC_CR2=0x44; // turn on timer and interrupt
RTC_WPR=0xFF; // lock the device
main()
CLK_DIVR = 0x00; // Set the frequency to 16Mhz
CLK_PCKENR2 = 0x07; // clock for timer1
PC_DDR = 0x08; //direction input for push button
PC_CR1 = 0x08; //floating input pc3
PE_DDR = 0x80; // direction output for led
PE_CR1 = 0x80; // fast push pull mode
SetupTimers();
_asm("rim\n"); // enable interrupt
while(1)
PE_ODR &= ~(0x80);
