Hi,Working with stm8l15 with lora.When storing more than one 32 bit variable in eeprom memory continuously, downlink is not receiving and it gets queueing. What will be the reason.
‎2021-05-28 06:06 AM
How to store more than one 32 bit variable in eeprom memory in while loop and also to receive downlink?
Here,I have attached the code too.
‎2021-05-28 06:26 AM
I could not open the code you posted, but take in count that a programming takes 6 ms if not writing on already erased location.
If you need shorter write times: prepare the locations in advance by erasing them and write your data in blocks (64 bytes). A block write is just as fast as a byte/word write.
‎2021-05-28 06:54 AM
Hi Cristian Gyorgy,
This is the main code
int main( void )
LoRaMacPrimitives_t LoRaMacPrimitives;
LoRaMacCallback_t LoRaMacCallbacks;
MibRequestConfirm_t mibReq;
BoardInitMcu( );
BoardInitPeriph( );
Flash_setup();
DeviceState = DEVICE_STATE_INIT;
printf("ClassA app start\r\n");
count = FLASH_ReadByte(0x1002);
count <<= 8;
count |= FLASH_ReadByte(0x1003);
count <<= 8;
count |= FLASH_ReadByte(0x1004);
count <<= 8;
count |= FLASH_ReadByte(0x1005);
count1 = FLASH_ReadByte(0x1006);
count1 <<= 8;
count1 |= FLASH_ReadByte(0x1007);
count1 <<= 8;
count1 |= FLASH_ReadByte(0x1008);
count1 <<= 8;
count1 |= FLASH_ReadByte(0x1009);
Count_Read = count;
Count1_Read = count1;
printf("Count_Read:%lu\n",Count_Read);
printf("Count1_Read:%lu\n",Count1_Read);
while( 1 )
if(joined_finish==1)
count++;
count1++;
FLASH_Unlock(FLASH_MemType_Data);
FLASH_ProgramByte(0x1002, count>>24);
FLASH_ProgramByte(0x1003, count>>16);
FLASH_ProgramByte(0x1004, count>>8);
FLASH_ProgramByte(0x1005, count);
FLASH_ProgramByte(0x1006, count1>>24);
FLASH_ProgramByte(0x1007, count1>>16);
FLASH_ProgramByte(0x1008, count1>>8);
FLASH_ProgramByte(0x1009, count1);
FLASH_Lock(FLASH_MemType_Data);
// here it comes switch case statement
‎2021-05-28 08:31 AM
Every line in the code above will take 6 ms: 8x6=48 ms programming time.
Instead you could do only 2 writes, by writing only 2 4-byte words (at a word aligned address!): 2x6=12 ms,
Or, read first the block where you want to do the write into SRAM, fill in the 8 bytes and than write the 64/128 bytes block back in only 6ms.
I don't know your compiler, what function has defined for the word/block programming, but for sure it has one.
‎2021-05-28 09:34 AM
Ya. Thank you. It is worked by using word. Downlink is also working and storing also happening.
