2021-10-11 2:47 AM
I also tried to make some configuration changes in the code, like putting the halt mode or disabling the timers.
Kindly suggest me to solve this issue
2021-10-11 4:39 AM
Consider what you have attached externally and the current drawn from those components.
2021-10-11 4:58 AM
In our application, the motor is attached externally. Without motor also we have checked. Before going to halt mode, I have initialized unused gpio pin as Output push-pull, low level , Disabled peripheral clock.
Still power-consuming in mA.
