2016-02-03 11:31 PM
2016-02-06 01:42 AM
You can use STVD with Cosmic or Raisonance compilers. As I recall these are free upto 32KB size.See the linkhttp://www.st.com/st-web-ui/static/active/jp/resource/technical/document/user_manual/CD00283975.pdf
/*Please
mark helpfullif this post helps you or solves your problem.*/
/**disclaimer**/
/* I am not a person from ST Technical Support Team. So please verify/test any support/suggestion at your end.*/
/* This post is only for general support purpose and free of any charge.If you need any personal support for your work please contact at
embeddeddesign.help@gmail.com
2016-02-06 10:16 AM
You can use the C compiler SDCC with whatever IDE you like. NetBeans and Code::Blocks seem to be popular lately.
Philipp
