Firmware development tools for STM8L
ashelke
Posted on February 04, 2016 at 08:31
I would like to know which tools can be used like compiler, IDEs for developing firmware for STM8L micro controller.
#compilers #development-tools
pkumar1883
Posted on February 06, 2016 at 10:42
You can use STVD with Cosmic or Raisonance compilers. As I recall these are free upto 32KB size.
See the link
http://www.st.com/st-web-ui/static/active/jp/resource/technical/document/user_manual/CD00283975.pdf
/*Please
mark helpfull
 if this post helps you or solves your problem.*/
/**disclaimer**/
/* I am not a person from ST Technical Support Team. So please verify/test any support/suggestion at your end.*/
/* This post is only for general support purpose and free of any charge.If you need any personal support for your work please contact at
embeddeddesign.help@gmail.com
Philipp Krause
Senior II
Posted on February 06, 2016 at 19:16
You can use the C compiler SDCC with whatever IDE you like. NetBeans and Code::Blocks seem to be popular lately.
Philipp
