2019-09-03 03:17 AM
Use ST visual development and all of a sudden I get this message:
Failed to launch child process <gdb.exe>
>error=2 - "The system cannot find the file specified.
2019-09-03 03:26 AM
Don't know your IDE.
But general experience tells me that many applications cannot deal with several instances at the same time, and refuse to start under that circumstances.
I would check if some comatose instance of gdb.exe is still running.
And, of course, that the executable is still there.
2019-10-14 06:10 AM
For some reason all of a sudden it worked for some weeks and now I get the same error again out of the blue. Reboot of the PC with ST visual only did not solve the issue.
2023-01-03 11:17 PM
I had the same issue. uninstall and reinstall method did not work.
Update your windows, it works.
2023-07-19 06:00 PM
A few days ago, I made a mistake and left the weight on the return key, and a lot of STM32CubeIDE started up. I forcibly rebooted the PC in the middle, but after that I couldn't access ST-Link at all, so I had no choice but to process it on another PC.
Today, when I tried to debug with STVD (for STM8), I got the same message as the questioner. I thought that the ST-Link driver might be broken, so I reinstalled it, and it returned as if nothing had happened. Is it possible that the driver is corrupted?
