example: btjt I2C_SR3, BUSY, label; bit BUSY not defined
Options
‎2013-08-01 2:24 AM
Posted on August 01, 2013 at 11:24
maybe I make not correct entry?
so works: #define BUSY #1...btjt I2C_SR3, BUSY, label...if BUSY not defined:;#define BUSY #1...btjt I2C_SR3, BUSY, label...so not worksBUSY isn't present on the map? or or i have not a right record?
Options
‎2013-08-01 2:45 AM
Posted on August 01, 2013 at 11:45 A microcontroller hardware definition is stored in an include file. For instance, I2C_SR3 is taken from this file. This include file, is seldom incomplete, because it doesn't define the bits inside an hardware register, as it should be for I2C_SR3_BUSY bit. If you want to remove these errors, you have to insert your definitions in the original include file so that your new projects will benefit. There is a annoying thing: when you upgrade STVD, your ''extensions'' will be lost!
Options
‎2013-08-01 2:50 AM
Posted on August 01, 2013 at 11:50
thank you!
