CXSTM8 bug when writing to bit structure
wolfgang239955_stm1_st
Posted on October 11, 2012 at 09:36
To optimize the code I put nearly all the flags to bit structures. Now I came across a  bug in the CXSTM8 when writing to bits. Reading bits doesn't bring any problem.
The good news for me is that I found a workaround.
Here is the example:
typedef struct
int
    sem_on  :1;
/* bit */
int
    sem_off :1;
/* bit */
int
    sem_tog :1;
/* bit */
} key_;
/*struct*/
key_ key_x;
/*struct*/
key_* key_down = &key_x;
&sharppragma
section
const
/*struct*/
key_*
const
key_up = &key_x;
 void clear_key_updown(
void
/*struct*/
key_* p_key;
   key_down->sem_on = 0;
/* variable pointer ..
   - ******** ERROR:  bad addressing mode  *********/
   (*key_down).sem_on = 0;
/* alternate expression ..
   p_key = key_down;
/* pointer substitution - o.k. */
   p_key->sem_on  = 0;
   key_up->sem_on   = 0;
/* const pointer - o.k. */
   (*key_up).sem_on = 0;
/* alternate expression - o.k. */
/*---------end of file------------------------------*/
The workaround you can see is to substitute the specific pointers.
 WoRo
#cxstm8 #cxstm8
2 REPLIES 2
luca239955_stm1_st
Senior II
Posted on October 11, 2012 at 10:46
Hi Woro,
we cannot recreate your problem here: please let me know the version and compiler options used (here or to my email: luca dot ubiali _at_ cosmic dot fr)
Regards,
Luca (Cosmic)
Posted on October 12, 2012 at 08:30
Hi Luca,
thanks first for your well-known promt reply.
I'll append the list file to this posting.
The compiler command line is:
cxstm8 +mods0 +debug -pxp -no -pp -l -duC_MMI -dUART_SCI -iuc_mmi\include -iinclude $(ToolsetIncOpts) -cl$(IntermPath) -co$(IntermPath) $(InputFile)
Hope it will help solving the problem.
Best Regards,
WoRo
________________
Attachments :
cxstm8_bug_2012-10-11.ls : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzO9&d=%2Fa%2F0X0000000bL0%2FgFzizlQa6S.Qy6uZor1dKZlLOIqTkjO06F4CQ3MLCZc&asPdf=false
