Bug in ADC1_GetConversionValue() ?
klaasdc
Posted on February 20, 2012 at 12:46
I was trying to get the ADC working on an STM8S discovery, but left and right alignment setting of the ADC gives different results.
In the file stm8s_adc1.c of the standard firmware library there is:
/* Left alignment */
        /* Read MSB firts*/
        temph = ADC1->DRH;
        /* Then read LSB */
        templ = ADC1->DRL;
        temph = (u16)((u16)(templ << (u8)6) | (u16)(temph << (u8)8));
I suppose that last line should be
temph = (u16)((u16)(templ >> (u8)6) | (u16)(temph << (u8)8));
(shifting the lower byte in the other direction)
Right?
#adc-alignment-shift
1 REPLY 1
zhangjunhe11
Posted on July 21, 2012 at 07:45
I found the same problem as you,and I have sent a letter to st.com to submit the bug.
