STM32CubeProgrammer 2.4.0 (and its API) bug when writing STM32L0 EEprom section.
ALazr.1
When using the STM32CubeProgrammer 2.4.0 API to write the address 0x08080000 the API hangs (my program hangs). I tried the STM32CubeProgrammer software itself, if I choose the EEprom view (in the grid) and I modify any byte, when I validate modification using Enter key, the STM32CubeProgrammer software hangs also.
Hi @ALazr.1​
Could you please specify your board name.
Please check with the laste CubeProgrammer version then tell me if it correct the issue.
Best regards,
Nesrine
