st-link utility in windows11 not starting
zom
St-link utility does not start in windows11. How to manage this situation?
mfc140 was copied to windows11 (system(32also), VC++ was also installed but all in vain..
Guru
ST-Link Utility is deprecated. In your last thread, you were using STM32CubeProgrammer, which is the supported software now. Is there a reason you're not using it?
1 REPLY 1
Guru
