locked out of my stm32g431.
TMich.1
made my own board with stm32g431kb and accidentally disabled swd. I can't acces my board anymore and pulling up boot0 doesn't help.
16 REPLIES 16
What does the sw active mean then? If it doesn't disable sw?
i replaced the chip and it didnt solve the problem
i meant dissabled, sorry
was that chip preprogrammed? if it wasnt maybe you fried something else
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
it is a fresh chip from an unused stm32 nucleo that i took it from. I doubt i fried something because powerdraw was measured and never got high or hot. and I managed to make both boards work the first time for extended use.
I tried again and played with the frequency and i got in but during debugging it rather soon lost connection again. and i didn't manage to get it working after retrying
Does this mean bad connections?
Piranha
Chief II
Connect the NRST pin to debugger and set those in CubeProgrammer:
Connect mode: Under Reset
Reset mode : Hardware reset
I tried this with no succes
