How to fix: Error: Mass erase operation failed. / verify flash protection
‎2023-01-18 7:49 AM
After evaluating/flashing the SBSFU examples on the NUCLEO-G071RB evalboard it's not possible to erase full flash anymore. I get the error below. How to set factory defaults that erasing is possible again?
STM32_Programmer_CLI.exe -c port=SWD -e all
STM32CubeProgrammer v2.12.0
ST-LINK SN : xxxxxxxxxxxxxxxxxxxxxxx
ST-LINK FW : V2J40M27
Board : NUCLEO-G071RB
Voltage : 3.21V
SWD freq : 4000 KHz
Connect mode: Normal
Reset mode : Software reset
Device ID : 0x460
Revision ID : Rev B
Device name : STM32G07x/STM32G08x
Flash size : 128 KBytes
Device type : MCU
Device CPU : Cortex-M0+
BL Version : 0xB2
Debug in Low Power mode enabled
Mass erase ...
Please verify flash protection
STM32_Programmer_CLI.exe -c port=SWD -ob displ
Voltage : 3.21V
SWD freq : 4000 KHz
Device ID : 0x460
Revision ID : Rev B
Device type : MCU
BL Version : 0xB2
UPLOADING OPTION BYTES DATA ...
Bank : 0x00
Address : 0x40022020
██████████████████████████████████████████████████ 100%
OPTION BYTES BANK: 0
Read Out Protection:
RDP : 0xAA (Level 0, no protection)
BOR Level:
BOR_EN : 0x0 (Configurable brown out reset disabled, power-on reset defined by POR/PDR levels)
BORR_LEV : 0x3 (BOR rising level 4 with threshold around 2.9 V)
BORF_LEV : 0x3 (BOR falling level 4 with threshold around 2.8 V)
User Configuration:
nRST_STOP : 0x1 (No reset generated when entering Stop mode)
nRST_STDBY : 0x1 (No reset generated when entering Standby mode)
nRST_SHDW : 0x1 (No reset generated when entering the Shutdown mode)
IWDG_SW : 0x1 (Software independant watchdog)
IWDG_STOP : 0x1 (IWDG counter active in stop mode)
IWDG_STDBY : 0x1 (IWDG counter active in standby mode)
WWDG_SW : 0x1 (Software window watchdog)
RAM_PARITY_CHECK: 0x1 (SRAM parity check disable)
nBOOT_SEL : 0x1 (BOOT0 signal is defined by nBOOT0 option bit)
nBOOT1 : 0x1 (Boot from Flash if BOOT0 = 0, otherwise system memory)
nBOOT0 : 0x1 (nBOOT0=1)
NRST_MODE : 0x3 (Bidirectional reset: NRST pin configured in reset input/output mode (legacy mode))
IRHEN : 0x1 (Internal resets drives NRST pin low until it is seen as low level)
PCROP Protection:
PCROP1A_STRT : 0x0 (0x8000000)
PCROP1A_END : 0x0 (0x8000200)
PCROP_RDP : 0x1 (PCROP zone is erased when RDP is decreased)
PCROP1B_STRT : 0xFF (0x801FE00)
PCROP1B_END : 0x0 (0x8000200)
Write Protection:
WRP1A_STRT : 0x0 (0x8000000)
WRP1A_END : 0x0 (0x8000000)
WRP1B_STRT : 0x3F (0x801F800)
WRP1B_END : 0x0 (0x8000000)
FLASH security:
BOOT_LOCK : 0x0 (Boot based on the pad/option bit configuration)
SEC_SIZE : 0x0 (0x8000000)
- Labels:
STM32CubeProgrammer
‎2023-01-18 7:56 AM
Hello @Rena Z.​,
I'm seeing some PCROP and WRP are set. When a WRP or PCROP is set, mass erase is forbidden.
WRP or PCROP are enable when START_ADDRESS <= STOP_ADDRESS
First, disable PCROP and WRP protection, then proceed to the mass erase.
Let me know if it works.
Best Regards,
Gwénolé
‎2023-01-18 8:44 AM
seems that modifying PCROP1A_STRT does not work:
STM32_Programmer_CLI.exe -c port=SWD -ob PCROP1A_STRT=0x3F -ob displ
Voltage : 3.22V
SWD freq : 4000 KHz
Device ID : 0x460
Revision ID : Rev B
Device type : MCU
BL Version : 0xB2
Bank : 0x00
PROGRAMMING OPTION BYTES AREA ...
Bank : 0x00
Reconnecting...
DBG enabled successfully
Reconnected !
Bank : 0x00
OPTION BYTE PROGRAMMING VERIFICATION:
Error: Expected value for Option Byte "pcrop1a_strt": 0x3F, found: 0x0
Error: Option Byte Programming failed
‎2023-01-18 9:15 AM
Hello @Rena Z.​,
Can you try to read and change Option Bytes through CubeProgrammer?
I'll investigate Programmer_CLI.
Another test could be to read the Option bytes register in debug mode.
Best Regards,
Gwénolé
‎2023-01-18 9:49 AM
same issue with STM32CubeProgrammer.
how to read out in debug mode?
‎2023-01-18 10:09 PM
Here is an additional log where I have increased the verbosity level to 3:
07:03:34:480 : r ap 0 @0x1FFF6FFE 0x00000004 bytes Data 0xFFFF00B2
07:03:35:575 : r ap 0 @0x1FFF6FFE 0x00000004 bytes Data 0xFFFF00B2
07:03:35:724 : Option byte command : -ob PCROP_RDP=1 PCROP1A_STRT=0xff
07:03:35:729 : PROGRAMMING OPTION BYTES AREA ...
07:03:35:729 : Reading data...
07:03:35:781 : r ap 0 @0x1FFF77DD 0x00000004 bytes Data 0xFFFFFFFF
07:03:35:781 : Database: Config 0 is active.
07:03:35:782 : Warning: Option Byte: PCROP_RDP, value: 0x1, was not modified.
07:03:35:786 : Bank : 0x00
07:03:35:786 : Address : 0x40022020
07:03:35:787 : Size : 112 Bytes
07:03:35:787 : OB buffer: aafeffffff000000000000803f0000003f000000ff00000000000000ffffffff0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
07:03:35:788 : Buffer program...
07:03:35:842 : halt ap 0
07:03:35:842 : w ap 0 reg 15 PC (0x20000000)
07:03:35:895 : w ap 0 reg 17 MSP (0x20000500)
07:03:35:948 : w ap 0 reg 16 xPSR (0x01000000)
07:03:36:475 : w ap 0 @0x20000B20 : 0x00000200 bytes, Data 0x00000000...
07:03:36:490 : w ap 0 @0x20000000 : 0x00000004 bytes, Data 0x0000BE00...
07:03:38:106 : w ap 0 @0x20000004 : 0x000006F4 bytes, Data 0x4891B580...
07:03:38:212 : w ap 0 @0x20000B20 : 0x00000070 bytes, Data 0xFFFFFEAA...
07:03:38:212 : Loader write option bytes...
07:03:38:212 : Init flashloader...
07:03:38:237 : halt ap 0
07:03:38:303 : w ap 0 reg 0 R0 0x00000001
07:03:38:356 : w ap 0 reg 1 R1 0x00000000
07:03:38:410 : w ap 0 reg 2 R2 0x00000000
07:03:38:463 : w ap 0 reg 3 R3 0x00000000
07:03:38:516 : w ap 0 reg 4 R4 0x00000000
07:03:38:569 : w ap 0 reg 5 R5 0x00000000
07:03:38:622 : w ap 0 reg 6 R6 0x00000000
07:03:38:676 : w ap 0 reg 7 R7 0x00000000
07:03:38:729 : w ap 0 reg 8 R8 0x00000000
07:03:38:782 : w ap 0 reg 9 R9 0x00000000
07:03:38:835 : w ap 0 reg 10 R10 0x00000000
07:03:38:888 : w ap 0 reg 11 R11 0x00000000
07:03:38:941 : w ap 0 reg 12 R12 0x00000000
07:03:38:994 : w ap 0 reg 13 SP 0x00000000
07:03:39:048 : w ap 0 reg 14 LR 0x20000001
07:03:39:101 : w ap 0 reg 15 PC 0x20000005
07:03:39:155 : w ap 0 reg 16 xPSR 0x01000000
07:03:39:207 : w ap 0 reg 17 MSP 0x20000AF4
07:03:39:259 : w ap 0 reg 18 PSP 0x00000000
07:03:39:259 : run ap 0
07:03:39:310 : halt ap 0
07:03:39:342 : r ap 0 reg 0 R0 0x00000001
07:03:39:408 : w ap 0 reg 0 R0 0x40022020
07:03:39:461 : w ap 0 reg 1 R1 0x00000070
07:03:39:514 : w ap 0 reg 2 R2 0x20000B20
07:03:39:567 : w ap 0 reg 3 R3 0x00000002
07:03:39:620 : w ap 0 reg 4 R4 0x00000000
07:03:39:673 : w ap 0 reg 5 R5 0x00000000
07:03:39:726 : w ap 0 reg 6 R6 0x00000000
07:03:39:779 : w ap 0 reg 7 R7 0x00000000
07:03:39:833 : w ap 0 reg 8 R8 0x00000000
07:03:39:886 : w ap 0 reg 9 R9 0x00000000
07:03:39:939 : w ap 0 reg 10 R10 0x00000000
07:03:39:992 : w ap 0 reg 11 R11 0x00000000
07:03:40:045 : w ap 0 reg 12 R12 0x00000000
07:03:40:098 : w ap 0 reg 13 SP 0x00000000
07:03:40:151 : w ap 0 reg 14 LR 0x20000001
07:03:40:204 : w ap 0 reg 15 PC 0x2000007D
07:03:40:257 : w ap 0 reg 16 xPSR 0x01000000
07:03:40:311 : w ap 0 reg 17 MSP 0x20000AF4
07:03:40:364 : w ap 0 reg 18 PSP 0x00000000
07:03:40:365 : run ap 0
07:03:40:415 : WriteOB function terminated with connection error due to OB_Launch
07:03:40:428 : Reconnecting...
07:03:41:530 : ST-LINK SN : xxxxxxxxxxxxxxxxxxxxx
07:03:41:530 : ST-LINK FW : V2J40M27
07:03:41:532 : Board : NUCLEO-G071RB
07:03:41:533 : Voltage : 3.22V
07:03:41:832 : SWD freq : 15 KHz
07:03:41:833 : Connect mode: Normal
07:03:41:833 : Reset mode : Software reset
07:03:41:864 : Device ID : 0x460
07:03:41:891 : Revision ID : Rev B
07:03:41:918 : halt ap 0
07:03:41:935 : r ap 0 @0x4002103C 0x00000004 bytes Data 0x00000000
07:03:41:953 : w ap 0 @0x4002103C 0x00000004 bytes Data 0x08000000
07:03:41:954 : DBG enabled successfully
07:03:41:970 : r ap 0 @0x40015808 0x00000004 bytes Data 0x00000000
07:03:41:985 : w ap 0 @0x40015808 0x00000004 bytes Data 0x00001800
07:03:41:987 : r ap 0 @0x40015804 0x00000004 bytes Data 0x00000000
07:03:41:995 : w ap 0 @0x40015804 0x00000004 bytes Data 0x00000007
07:03:41:996 : Reconnected !
07:03:41:996 : Success with Time elapsed during Reconnect: 467 ms
07:03:41:997 : Reading data...
07:03:42:051 : r ap 0 @0x1FFF77DD 0x00000004 bytes Data 0xFFFFFFFF
07:03:42:051 : Database: Config 0 is active.
07:03:42:052 : UPLOADING OPTION BYTES DATA ...
07:03:42:052 : Bank : 0x00
07:03:42:053 : Address : 0x40022020
07:03:42:053 : Size : 112 Bytes
07:03:42:054 : Reading data...
07:03:42:153 : r ap 0 @0x40022020 0x00000070 bytes Data 0xFFFFFEAA
07:03:42:156 : OPTION BYTE PROGRAMMING VERIFICATION:
07:03:42:156 : Error: Expected value for Option Byte "PCROP1A_STRT": 0xFF, found: 0x0
07:03:42:213 : Error: Option Byte Programming failed
07:03:42:250 : Reading data...
07:03:42:263 : r ap 0 @0x1FFF77DD 0x00000004 bytes Data 0xFFFFFFFF
07:03:42:264 : Database: Config 0 is active.
07:03:42:265 : Time elapsed during option Bytes configuration: 00:00:06.482
07:03:42:537 : r ap 0 @0x1FFF6FFE 0x00000004 bytes Data 0xFFFF00B2
07:03:42:537 : UPLOADING OPTION BYTES DATA ...
07:03:42:537 : Bank : 0x00
07:03:42:537 : Address : 0x40022020
07:03:42:537 : Size : 112 Bytes
07:03:42:538 : Reading data...
07:03:42:538 : r ap 0 @0x40022020 0x00000070 bytes Data 0xFFFFFEAA
07:03:42:545 : r ap 0 @0x1FFF6FFE 0x00000004 bytes Data 0xFFFF00B2
‎2023-01-18 10:53 PM
What a pitty! All the nice CLI options to restore the option bytes are only available for STM32WL devices ???
STM32_Programmer_CLI.exe -c port=SWD -ob unlockchip
Voltage : 3.21V
SWD freq : 4000 KHz
Device ID : 0x460
Revision ID : Rev B
Device type : MCU
BL Version : 0xB2
Bank : 0x00
Error: Only STM32WL devices are supported.
Error: Fail to unlock chip
STM32_Programmer_CLI.exe -c port=SWD -setdefaultob
Voltage : 3.21V
SWD freq : 4000 KHz
Device ID : 0x460
Revision ID : Rev B
Device type : MCU
BL Version : 0xB2
Set default OB for STM32WL
‎2023-01-19 1:49 AM
Hello @Rena Z.​,
I'll provide you a quick script to reset the Option bytes by software.
I'm quite surprising about the behavior you faced.
Best Regards,
Gwénolé
‎2023-01-19 2:24 AM
Hello @Rena Z.​ ,
To reset the PCROP1 you need also to perform a transition from RDP1 to RDP0.
So it means:
1-Check PCROP_RDP and put RDP=BB (level 1 reed protection)
2-Put RDP=AA (level 0, no protection)
3- Your PCROP registers have the default values.
Just be careful to not put the circuit as RDP level 2 otherwise the circuit will be blocked for ever.
Best regards,
Simon
‎2024-04-29 7:32 AM
I have a similar issue, can i have the script that put registers to default value ?
