Hello, I'm using STM32F072B DISCO board, want to send CAN messages to motor controller. It stops after couple of seconds.
‎2021-09-20 8:13 AM
I'm using this command for Tx, and please let me know if I'm using correct clock config as well.
uint8_t csend[] = {0x00,0x00,0x27,0x10}; // Tx Buffer
HAL_CAN_AddTxMessage(&hcan,&txHeader,csend,&canMailbox); // Send Message
Clock config:
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI14|RCC_OSCILLATORTYPE_HSI48;
RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
RCC_OscInitStruct.HSI14State = RCC_HSI14_ON;
RCC_OscInitStruct.HSI14CalibrationValue = 16;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI48;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
Error_Handler();
I also get this in debugger console
Debugger connection lost.
Shutting down...
- Labels:
STM32CubeProgrammer
STM32F0 Series
‎2021-09-21 2:45 AM
Hello @SPati.9​ ,
I think your issue is related to STM32CubeProgrammer issue.
I advise you to check these posts: post1 and post2.
Hope this helps!
Please keep me informed about your update on this issue.
Imen
Imen
‎2021-09-21 7:54 AM
It did not work, still
Shutting down...
I've tried resetting from STM32 programmer, mass_erase, software system reset in debugger and reinstalling Cube IDE as well. I'm using MAC.
