Custom STM32H743IIK6 Board Flashing Error: No STM32 target found!
Options
‎2023-08-22 1:39 AM
I am trying to flash a custom PCB having STM32H743IIK6 MCU using SWD interface.
I have tried below methods but all are Failing.
- Flashing using 'STM32CubeProgrammer' using all 'Mode' and 'Reset Mode' options Failed
- Flashing using STM32CubeIDE tried using STLINK SWD and J-Link SWD Failed
- Flashing using STM32 ST-Link Utility Failed.
Below is the Schematic of the programming and power supply section of the MCU.
I have assembled 2 different boards and in all 2 boards, Most of times, I am getting 0V on VCAP pins. but sometimes this VCAP voltage fluctuate around 0.7V to 1.1V.
Labels:
STM32CubeProgrammer
Options
‎2023-08-22 2:42 AM
1 REPLY 1
Options
‎2023-08-22 2:42 AM
Problem solved!
It was the issue of MCU BGA pad soldering.
