CubeProgrammer works, but Programmer_CLI fails
‎2023-08-02 1:43 AM - edited ‎2023-08-02 2:11 AM
I have a situation where I can successfully program the target using STM32CubeProgrammer, but it fails when I try to do the same with STM32_Programmer_CLI.exe with an error:
Error: failed to erase memory
Both are v2.13.0.
The command line I used:
STM32_Programmer_CLI.exe -c port=SWD -d "firmware.bin" 0x08000000 -vb 3
Attached are the verbose level 3 output from each.
I am attempting to figure out why STM32CubeIDE fails to download code for debug. It also encounters the same failed to erase memory error.
Appreciate any help anyone can give me. Thanks.
- Labels:
STM32CubeProgrammer
‎2023-08-07 4:27 AM - edited ‎2023-08-07 4:28 AM
I got it working. The only thing that I added was `freq=8000` to the command line:
STM32_Programmer_CLI.exe -c port=SWD freq=8000 -d "firmware.bin" 0x08000000 -vb 3
In the STM32CubeIDE debug configuration, I also had to change the Frequency from `Auto` to `8000` and it started working.
‎2023-08-02 2:52 AM
Hello @kamion1 ,
Thanks for your feedback,
I wasn't able to replicate the issue on my end. I suggest upgrading to the latest version (v2.14.0).
Can you please try using v2.14.0 and inform me if the issue still persists?
Sara.
‎2023-08-02 3:30 AM
Hi @Sara BEN HADJ YAHYA ,
I have repeated the same steps with v2.14.0 and the result is the same.
Attached verbosity 3 logs.
