Can someone share the commands (CLI) to establish connection once (-c) and do all flash steps, finally disconnect
PS.7
We are trying to execute the following steps,
"C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI" -c port=SWD --erase all
"C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI" -c port=SWD -w "C:/Users/Public/Documents/p2_hi_primary_bl.hex"
"C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI" -c port=SWD -w "C:/Users/Public/Documents/p2_hi_secondary_bl.hex"
"C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI" -c port=SWD -w "C:/Users/Public/Documents/p2_hi_fct.hex"
"C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI" -c port=SWD -rst
We are getting error when we run each command. can we run connect only once, then proceed flash steps, and after flashing disconnect?
You should be able to chain commands. What error are you getting?
Mike_ST
At least you should be able to merge the 2 first and the 2 last commands :
C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI -c port=SWD mode=normal -e all -d "C:/Users/Public/Documents/p2_hi_primary_bl.hex"
C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI -c port=SWD mode=normal -d "C:/Users/Public/Documents/p2_hi_secondary_bl.hex"
C:/Program Files/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32_Programmer_CLI -c port=SWD mode=normal -d "C:/Users/Public/Documents/p2_hi_fct.hex" -rst
I have never tried to download several hex on the same line.
