X-CUBE-IRREMOTE for stm32g030f6p6
Ashja .S
 Hey,
I am trying to include X-CUBE-IRREMOTE for stm32g030f6p6 but it doesnt show up in software packs in cubeMX
if i try to manually install it it gives an error of invalid packet
Peter BENSCH
The core of the question relates to the same cause as has been discussed before in the community. At that time it was about X-CUBE-EEPROM, but the principle is the same.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
Ashja .S
hey @Peter BENSCH​ ,
Thanks for the promt reply.So i can use the drivers inside this X-CUBE-IRREMOTE and use them ?
Peter BENSCH
Yes, you can directly use them.
