There are some issues when generate code with STM32CubeMX 5.6.1 and run the code
‎2020-04-12 3:55 AM
- there is a strange issue when generate a code. The code generation cannot be ended with an error - "But EWARM V8project generation have a problem. before the code can be generated without an errors.
- After run generated code, always be hang at SystemClock_Config(); halt on HSI_TIMEOUT_VALUE.
I have no issues for the code with the previous version 4.27.0.
Please advise on these two issues. thanks.
Jiannong
- Labels:
STM32CubeMX
‎2020-04-14 2:50 AM
Hi @Community member​
Could you please share your .ioc file to check the issue ?
Nesrine
‎2020-04-14 6:40 AM
Hi Nesrine,
I already deleted not working .ioc file. Attached the working one. This new version .ioc file migrated from old version of STM32CubeMX.
There could be a possiuble reason for .mxproject. in the file, the project folder is not the current project folder.
I will share with you .ioc file when face the problem again.
Thanks & regards,
Jiannong
‎2020-04-14 7:15 AM
Hi @Community member​ ,
Okay, you are welcome any time :)
Best regards,
Nesrine
