The startup code paths in the cmake files for the H745 created with CubeMX v6.12 are incorrect.
‎2024-07-09 11:50 PM
H745 startup files are located in "CM7/Core/startup/startup_stm32h745xx_CM7.s" or "CM4/Core/startup/startup_stm32h745xx_CM4.s".
However, the build source path for the startup files in the mx-generated.cmake in each core's folder is ". /Startup/startup_stm32h745xx_CM7.s" or ". /Startup/startup_stm32h745xx_CM4.s".
Therefore, the cmake file must be changed to build.
STM32H7 series
‎2024-07-15 2:36 AM
Hello @imagawa122
I tried to reproduce the described behavior but the code is compiled correctly.
And after checking the mx-generated.cmake the startup file path is defined this way:
- ./Core/Startup/startup_stm32h745xx_CM7.s
- ./Core/Startup/startup_stm32h745xx_CM4.s
Could you provide a simplistic project showing this behavior?
BR,
Semer.
‎2024-08-31 1:53 PM - edited ‎2024-08-31 1:55 PM
I was about to create a post to report the same bug. the mx-generated.cmake file aims to ./Startup/startup_stm32h755xx_CM7.s
but the real path is
./Core/startup/startup_stm32h755xx_CM7.s
I've searched for text on the CubeMX directory trying to identify if there is a template with this path incorrectly configured but to no avail...
Not to mention that I have to change this path for CM4 and CM7 cores every time I auto generate code with CubeMX
Any advice on how to investigate or solve this issue?
Thanks!
‎2024-09-09 6:00 AM
Can we please get more feedback from ST to solve this issue with CubeMX?
I've found this issue also reported in another post:
‎2024-09-12 11:07 AM
While we wait for a proper answer from ST, this is how I'm handling it in Linux.
I've created a script to be run before Build and Flash to execute the replacements,
Regards.-
‎2024-11-10 3:31 AM
I confirm this issue.
Environment: CubeMX 6.12.1 on Debian
Board: Nucleo H755ZI
Steps to reproduce:
1. Configure only the project path and set Toolchain to CMake in CubeMX (no additional settings applied).
2. Click on "Generate Code."
Issue: CubeMX generates incorrect paths in the mx-generated.cmake files for each core. Either the CMake files are created incorrectly, or the paths are incorrectly named.
Generated Path: ./Startup/startup_stm32h755xx_CM7.s
Expected Path: ./Core/startup/startup_stm32h755xx_CM7.s (as in the cmake file)
