2024-07-15 06:49 AM
Hi all!
Thanks again for the help so far.
Just another question, is it possible (or normal?) when creating a pack to have it insert snippets of code into main.c just like the code snippets that get inserted by the cube when you change peripherals etc?
Thanks again.
2024-07-24 07:27 AM
2024-07-24 07:27 AM
found what I was looking for, add an "Application"
