STMCubeMx 6.14.1 Bug in ADC Clock Prescaler code generation
  • April 29, 2025
  • 540 views
When generating code with CubeMx version 6.14.1 there is a new bug (compared to version 6.13.0 where it worked fine).
MCU: STM32U5A5QJIxQ
Peripherals: ADC1/2 and/or ADC4
RCC Clocksource: SYSCLK
When you change parameter setting in ADC_Settings "Clock Prescaler" it has no effect on generated code. There should be following code (was generated like this in version 6.13.0):
LL_ADC_CommonInitTypeDef ADC_CommonInitStruct = {0};
ADC_CommonInitStruct.CommonClock = LL_ADC_CLOCK_ASYNC_DIV4;
LL_ADC_CommonInit(__LL_ADC_COMMON_INSTANCE(ADC1), &ADC_CommonInitStruct);
The ADC clock prescaler setting is common for all ADCs and DAC, but in version 6.14.1 there is no code generated which sets the prescaler anywhere!
Best answer by Mahmoud Ben Romdhane
Hello @eliasgruber ,
Let me thank you for bringing this issue to our attention.
An internal ticket is raised to the development team (Internal Ticket Number: 208960)
Thanks.
Mahmoud
Hello @eliasgruber
First let me thank you for posting and welcome to ST community.
Your request is under investigation, and I will get back to you ASAP.
Thanks.
Mahmoud
Thanks.
Mahmoud
