Visitor II
Apr 11, 2024 6:58 AM UTC
[STM32L412] CubeMX generated LL code for ADC TEMP channel
I'm using CubeMX 6.11.0 (STM32L4 package version 1.18.0) to generate code for the STM32L412 with LL drivers.
My configuration enables the VREFINT and TEMP channels for ADC1.
The generated function MX_ADC1_Init() contains the line
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC1), LL_ADC_CHANNEL_VREFINT|LL_ADC_CHANNEL_TEMPSENSOR);
which should actually be
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC1), LL_ADC_PATH_INTERNAL_VREFINT | LL_ADC_PATH_INTERNAL_TEMPSENSOR);
This prevents correct temperature channel measurements.
STTwo-32
STTwo-32Best answer
Apr 11, 2024 6:03 PM UTC
Hello @ml512 and welcome to the ST Community :smiling_face_with_smiling_eyes:.
Thank you for reporting this. I've escalated this to the concerned team for correction (under internal ticket number 179295).
Best Regards.
STTwo-32
1 reply
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
