STM32H7A3 CubeMX no alternate function settings for PC2_C and PC3_C pins
‎2021-09-15 9:48 PM
For STM32H7A3VIT6, in the latest CubeMX software I cannot assign alternate functions to the PC2_C and PC3_C pins. But according to the datasheet it should be possible by closing the analog switches to PC2 and PC3 by modifying SYSCFG_PMCR registers.
I've checked the alternate function settings are indeed present for older STM32H7 lines. But not for STM32H7Ax/Bx. Is this a bug in CubeMX or a hardware limitation?
- Labels:
STM32CubeMX
STM32H7 series
‎2021-09-16 7:20 AM
I've rechecked the version and found out that I'm using 6.1. After upgrading to 6.3 it works as expected.
Thank you very much for your help!
‎2021-09-16 2:39 AM
Welcome to the STM32 community @Jack123​ !
I truly couldn't reproduce this issue.
So can you please provide me with your .ioc file ?
Best regards,
Mouadh.
‎2021-09-16 4:02 AM
I think this was an issue in older CubeMX versions. Latest is v6.3.
‎2021-09-16 7:20 AM
