2018-10-29 01:25 PM
In STM32CUBEMX software version 4.27.0 , when I generate code for keil, it changes compiler setting from my own -O0 parameter to -O3. If I change back this parameter in keil, in next code generation of stm32cubemx it changes this parameter again. It is very annoying. V4.26.0 is OK.
Thanks,
2018-10-31 03:26 AM
Hi @hs.
It is fixed for the next release.
Sorry for the inconvenience
Regards,
Nawres.
2018-10-30 02:25 AM
Hi @hs. ,
This is reported internally. Sorry for any encountered inconvenience.
Khouloud.
2018-10-31 03:26 AM
Hi @hs.
Regards,
Nawres.
