STM32CubeMX 5.6.0 (latest) Code Generation Freezes
SidBr
I'm trying to generate the code on the STM32F407G-DISC1 evaluation board for the TrueStudio project environment.
The code generation just freezes.
Has anyone else seen this?
I'm running on Windows 7 Pro, 64 b0693W000000VReZQAW.pngit
I've tried different combinations of projects and processors but the result is the same.
Imen.D
Hello @SidBr​ ,
Please check if your project path location contains special character as "#" or "&".
Then, please keep us informed about your progress.
Best Regards,
Imen
Imen
8 REPLIES 8
Imen.D
Hello @SidBr​ ,
Best Regards,
Imen
Imen
Thanks @Imen DAHMEN​
This was the problem.
Since I started working from home, the IT department gave me a laptop where the User account was “R&D�?, which appeared in the STM32CubeMX repository path.
I created a new admin user not containing an '&', and it now works.
This has solved most of my other issues.
I already reported highlighted this issue internally to CubeMx team for analysis.
Best Regards,
Imen
Imen
sschu.236
Hello, I have the same thing when I had upgrade the system windows 10 (1093 -> 1909). And it's the same even when I try to generate for stm32cubeide
Hi @sschu.236​ ,
Have you managed to fix it?
Take a look in the 'Project Manager' options and check to see what the path of the 'Repository' is.
'&' and '#' breaks the code generation.
Hello, I looked the path, i don't have any special caracters. My path is like that:
Hello, I resolved the issue. My work folder contained effectively a special character. I changed the work folder's name and all is OK. Thank you for your suggestion. :ok_hand:
Jim Frederick_2
I see this frequently, randomly, roughly 2 out of 10 times, on several projects. The associated paths have no special characters other than a space. My solution is to kill the process with the Windows process manager and try again. The odds are in my favor!
