STM32CubeMX 5.1.0 Can't open Docs & Resources.
‎2019-04-23 6:17 PM
When I opened my projects, The menu "Docs & Resources" is gray, and can't be clicked. I tried "Refresh Data", it didn't help. What should I do? Thank you.
STM32CubeMX
‎2019-04-25 1:26 AM
What is the MCU reference you are using ?
‎2019-06-25 2:11 AM
I have this problem in 5.2.1 as well, so far I've failed to find a chip it works with. If I'm in the chip/board selection process then the link there seems to work but once a project has been opened that link Jeason mentions from the help menu is grey and not clickable.
Current project is STM32F373 based, previous one STM32L452. First project was started via chip selection the 2nd via selecting the appropriate Nucleo board. Worked fine before I upgraded to the this version.
‎2019-06-26 9:04 AM
Hi Jeason ,
Can you please send me your ioc file?
Best Regards,
Wael
‎2019-06-26 9:41 AM
