Searching for STM32s with Advanced Motor Control Timers
rogdiv
I'm searching for a MCU with one or two advanced motor control timers to control 1 or 2 bldc motors.
For this purpose I use the MCU selection tool from here: STM32 family of 32-bit microcontrollers (MCUs) - STMicroelectronics
When I use the filter for one or two advanced motor control timers the MCUs from the STM32G series are never displayed and I don't understand why? How should I search for all MCUs with motor control functionalities?
Thanks for every hint!
Best regards,
Roger
rogdiv
Hi Andrew,
Thanks for this tip, I have also found this page STM32 Ecosystem for Motor Control - STMicroelectronics. Which is very useful because it shows an overview over the different MCUs for motor control applications.
Andrew Neil
What if you use the selector on the STM32G0 page?
https://www.st.com/en/microcontrollers-microprocessors/stm32g0-series/products.html
rogdiv
Hi Andrew,
you're welcome.
if your problem is solved, please mark the solution.
