2020-08-16 1:28 AM
Downloaded and installed the latest Java development kit. Tried installing SetupSTM32CubeMX-6.0.1 via: sudo java -jar SetupSTM32CubeMX-6.0.1.exe but get this error message: Error: Unable to access jarfile SetupSTM32CubeMX-6.0.1.exe .
Any ideas?
2020-09-03 2:24 AM
Hi @MBudz.1 ,
Good news !
Can you make the solution as Best Answer to help others community members if facing the same issue?
Aymen.
2020-09-03 2:27 AM
Not sure how to do that? If you tell me I can sort it asap.
Cheers
2020-09-03 2:27 AM
Done it
