Matlab Cant Launch CubeMX
k239955_st
Posted on December 06, 2015 at 12:58
Hi. I am trying to create stm32f401 code using matlab. I can install the mat_target file and configure simulink code generator. My problem is that when i am trying to build my project, CubeMX does not start and the matlab is busy for many hours. In matlab diagnostic viewer the last message i get is that
♯♯♯ Open STM32CubeMX for configuration and project code generation. Start command: ''C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeMX\STM32CubeMX.exe'' -q ''D:\Electronics\STM32F401\Projects\Matlab Test2\Matlab Test\.script''
I am using matlab 2014a.
Any help please?
#stm32 #cubemx #matlab
Posted on December 07, 2015 at 13:46
It is certainly because of Java version installed.
you must install Java 64bits.
Pascal
