2020-11-18 2:28 AM
Hi, My project is on a Stm32H7 I'm using freeRTOS and LWIp. For testing I'm using a sample project generated by cubemx and http_netconn web server.
When I generated the project with cubemx 5.6.1 it's working good.
With CubeMx 6.0.1 http request are receive but data's are send very slowly and it fail.
I checked a lot of parameters but I don't find any difference.
If someone could help me ?
Valentin
2020-11-20 9:12 AM
Hello Piranha,
Let me thank you for your post, first and foremost; Amel and I have both been working on trying to have this fixed for a good while now.
We have contacted the teams responsible and have opened a few requests to get this sorted - and it is also disappointing for us that little progress has been made. The reason I thank you for your post is that I will use it to push the appropriate teams harder and advocate for this correction to take place as soon as possible, and your voice will be important for this.
My apologies for the delay, but I assure you that I am doing all I can on this regard.
Imen
2020-11-18 2:39 AM
Hello @VAUDI ,
If possible to share your ioc file, this will help our CubeMX team to check and analyze your issue.
Imen
2020-11-18 3:26 AM
https://community.st.com/s/question/0D50X0000C6eNNSSQ2/bug-fixes-stm32h7-ethernet
More than a year has passed and almost nothing has been done... Not even the reference manual misinformation about Tx buffer complete interrupts have been corrected, which I explained in very fine detail - even more details than should be necessary. That takes a maximum of few hours to fix it!
Customers deserve a clear answers to these simple questions:
2020-11-18 11:25 PM
2020-11-20 9:12 AM
Hello Piranha,
Imen
