Is it possible to use the X-Cube-TOF1 package with X-Nucleo-53L0A1?
‎2021-11-09 7:57 AM
My question says it all. I would like to use X-Cube-TOF1 package with X-Nucleo-53L0A1. I do not see that board mentioned in the list of options.
- Labels:
STM32CubeMX
STM32L0 Series
‎2021-11-10 5:58 AM
Hi @Community member​ ,
X-CUBE-53L0A1 is not enhanced for STM32CubeMX software tool. It is already discussed in this link Can't load X-CUBE-53L0A1 (st.com).
Regards,
Sara.
‎2021-11-10 2:11 AM
It is not possible to use X-Cube-TOF1 with X-Nucleo-53L0A1, However The X-CUBE-53L0A1 software package is associated with the X-NUCLEO-53L0A1.
Regards,
Sara.
‎2021-11-10 5:33 AM
Thank you Sara, unfortunately X-CUBE-53L0A1 does not appear compatible with the current version of STM32CubeIDE. I tried it several months ago and even after days of trying could not get it into Cube.
Sid
‎2021-11-10 5:58 AM
Regards,
Sara.
‎2021-11-11 6:22 AM
Many thanks @Sara BEN HADJ YAHYA​ , my client has decided to change to the most recent ToF device from ST, and that is supported by X-Cube-TOF1 :)
Thank you,
'Sid
