In STM32CubeMX, What is thread-safe-settings
ADani.2
KnarfB
For a long time, the standard library was not RTOS aware. I.e. functions like malloc behaved badly when a RTOS scheduler kicked in. This was fixed recently by the new dialog box. If you say yes, a thread-safe version of the library is used which induces some overhead. For non-RTOS code, answering no is fine.
disclaimer: did not test the new behaviour
hth
KnarfB
6 REPLIES 6
KnarfB
hth
KnarfB
There are 6 different options in this dialog box. What is the use of each option. Is there any documentation.
Thank you,
Hi @ADani.2​ ,
For now, there is no documentation on thread safe settings but the request of documentation is already reported internally.
I will keep you posted with the updates.
Sara.
Thank you, *Avinoam Danieli * Senior Electrical Engineer P:0722793123 m: +972-54-4629386 w: getfabric.com <>
Sara BEN HADJ YAHYA
Please check the AN5731 which is now available in https://www.st.com, it describes the thread-safe solution, implemented in STM32CubeMX and STM32CubeIDE.
Direct link: https://www.st.com/resource/en/application_note/an5731-stm32cubemx-and-stm32cubeide-threadsafe-solution-stmicroelectronics.pdf
Sara.
Very helpful. Thank you *Avinoam Danieli * Senior Electrical Engineer P:0722793123 m: +972-54-4629386 w: *getfabric**.com* <>
