I would like to know if ST provides support for NuttX, the embedded OS that is POSIX compliant. I am wondering if there's an STMCube-like codebase of drivers or some sort of manual for getting started with NuttX.
Jennifer D
I haven't seen them actively doing so. You'd perhaps have more luck at a NuttX forum
Jennifer D
Can you recommend one?
This is a bit of an uphill ski, I'm not the one with interest in the OS.
OS's tend to be driven by their adherents. ie I should port this to one of the most popular lines of micro-controllers in modern history..
Google suggests "NuttX Community Forum - NuttX Real-Time Operating System"
If you're not doing several $M business with ST they're probably not going to provide much direct engineering support to your ideas/projects
