I have a error message when i open the cube mx
khyun.8
​whenever i open cube mx, this error message make me be nervous
4 REPLIES 4
AvaTar
Lead
Have you installed it with Admin rights ?
Have you been following the hints given in the message window ?
Khouloud GARSI
Lead II
Hi @khyun.8​ ,
I will highlight your case internally and one of our STM32CubeMX experts will answer you ASAP. Meanwhile, could you please precise which version you're using and answer the questions asked by @Community member​ , this will help us to debug your issue.
Khouloud.
Nawres GHARBI
Hi @khyun.8​
It seems that you have not access to the updater folder due to access rights
As workaround
  • Try to change the updater folder to a placement you have access On
  • Be sure you installed CubeMX with admin rights
  • try to run CubeMX with admin rights
Perhaps also report make/version of anti-virus software running, and version of Windows and Java. ​
