Error Log: CubeMX plugin appears to be active, Log4j initialization might be too late.
‎2023-01-31 5:03 AM
I am running STM32CubeIDE Version: 1.11.2 Build: 14494_20230119_0724 (UTC). When I startup CubeIDE, I am seeing the following error in the Error Log:
"CubeMX plugin appears to be active, Log4j initialization might be too late."
I would appreciate it if someone could point me in the correct direction to resolve it (or ignore it). I am relatively new to CubeIDE, as I have primarily been doing my STM32 work from the command line with Makefiles. CubeIDE seems to be working fine so the error is not slowing me down at the moment.
STM32CubeIDE
STM32CubeMX
‎2023-01-31 5:04 AM
Additional information from the log file:
eclipse.buildId=Version 1.11.2
java.version=11.0.16
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64
‎2023-02-01 8:37 AM
Hello @BHime​
Could you provide the complete log files found under the "workspace\.metadata" directory:
- .ide.log file
- .log file
Kind regards,
Semer.
‎2023-02-01 9:35 AM
‎2023-02-01 9:35 AM
‎2023-02-01 9:36 AM
Also, there is a .log4j.xml file that might be relevant.
‎2024-02-28 5:03 AM
I encounter the same error. Not sure what happened? I am using stm32cubeide 1.14.1
‎2024-04-06 10:24 AM
Any solution on this problem?!, I have the same error message...
‎2024-04-11 1:03 PM
I have the same problem. Any solution yet?
‎2024-11-07 4:46 AM
I encounter the same error. I am using stm32cubeide 1.16.1
