2026-03-02 3:37 PM - edited 2026-03-02 3:44 PM
With HPDMA configured for SAI1A, no DMA setup code is generated with CubeMX 6.17.0. See attached IOC file as an example. Possible that I'm missing a required setting, but I can't find anything.
Edit: Fully deleting and re-creating project seems to have fixed it :shrug:.
2026-03-02 11:08 PM
Hello @therealergo
Thank you for your contribution.
Sometimes the IOC file can become corrupted. Since you fully deleted and re-created the project and everything then worked as expected, this behavior does not appear to be a CubeMX bug in this case.
THX
Ghofrane
2026-03-02 11:08 PM
Hello @therealergo
THX
Ghofrane
