2026-03-30 12:16 PM
I’m trying to understand how the build setup works in VS Code.
Could you advise where and how to configure VS Code so that .bin and .hex files are always generated when building both Debug and Release configurations?
Is this controlled via CMake, or through one of the .json configuration files?
Whichever approach is correct, could you also share the specific scripts or commands that need to be used?
Thank you :)
2026-03-31 6:07 AM - edited 2026-03-31 6:12 AM
Similar to @Julien D 's answer, just slightly slimmer. I do like Julien's usage use "arm-none-eabi-objcopy" where mine is abstracts it with "CMAKE_OBJCOPY" .
What it's doing below:
** Note the "file(MAKE_DIRECTORY...)" command is commented out, as the OS generates it on copy.
# Generate HEX file
set(HEX_FILENAME "MYPROJ-${CMAKE_PROJECT_NAME}-v0.0.1.hex")
add_custom_command(
TARGET ${CMAKE_PROJECT_NAME}
POST_BUILD
COMMAND ${CMAKE_OBJCOPY} -O ihex $<TARGET_FILE:${CMAKE_PROJECT_NAME}> ${HEX_FILENAME}
# COMMAND ${CMAKE_OBJCOPY} -O binary ${CMAKE_PROJECT_NAME}.elf ${CMAKE_PROJECT_NAME}.bin
COMMENT "Generating HEX '${HEX_FILENAME}' for '${CMAKE_PROJECT_NAME}'")
# Copy generated file to project's root "output" folder
# file(MAKE_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/../../../../BLARG)
add_custom_command(
POST_BUILD
COMMAND ${CMAKE_COMMAND} -E copy
"${CMAKE_CURRENT_BINARY_DIR}/${HEX_FILENAME}"
"${CMAKE_CURRENT_SOURCE_DIR}/../../output/${HEX_FILENAME}"
COMMENT "Copying HEX file to output folder.")
2026-03-31 1:54 AM
Hi @Ricko,
This can be achieved via CMake yes, put something like this in your CMakeLists.txt and probably adapt it to your project:
if(CMAKE_BUILD_TYPE STREQUAL "Debug")
add_custom_command(
TARGET ${YOUR_TARGET_NAME}
POST_BUILD
COMMAND ${CMAKE_COMMAND} -E echo Post-build command for Debug: arm-none-eabi-objcopy -O binary $<TARGET_FILE:${YOUR_TARGET_NAME}> "${CMAKE_BINARY_DIR}/${YOUR_TARGET_NAME}.bin"
COMMAND arm-none-eabi-objcopy -O binary $<TARGET_FILE:${YOUR_TARGET_NAME}> "${CMAKE_BINARY_DIR}/${YOUR_TARGET_NAME}.bin"
WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
BYPRODUCTS "${CMAKE_BINARY_DIR}/${YOUR_TARGET_NAME}.bin"
VERBATIM
endif()
if(CMAKE_BUILD_TYPE STREQUAL "Release")
add_custom_command(
POST_BUILD
COMMAND ${CMAKE_COMMAND} -E echo Post-build command for Release: arm-none-eabi-objcopy -O binary $<TARGET_FILE:${YOUR_TARGET_NAME}> "${CMAKE_BINARY_DIR}/${YOUR_TARGET_NAME}.bin"
VERBATIM
endif()If your commands are the same it should be possible to factorize the 2 add_custom_command() in a single one by removing the if/endif statements.
# Generate HEX file
add_custom_command(
POST_BUILD
add_custom_command(
POST_BUILD
2026-04-03 4:16 PM
