CubeMX more GPIO View and FATFS
wj.anggara
Dear ST support,
1. The following attached the issue of some pins being overwritten by the last pin configuration, I also didn't find the hide feature in the configuration pop-up.
how i can solve this issue ?
2. what is the correct configuration for 1-bit sdcard mode on BSP FATFS (Platform proposal)?
because when I was ignored then I got a warning like in figure 2
Thank you in advance
Martin Franke
I'm also having the same issue. I cannot scroll through the GPIO pins, and when I click on one the configuration pop-up covers other pins. Please add a scrollbar
I'm not sure ST has anyone responsible for QA of the user interface, or regression testing of the software more generally. Be interesting to see the ISO docs explaining the process they use...
