2023-07-27 2:54 AM
Hi there,
is there a possibility in CubeMX to add a remark/comment/note to a peripheral or its configuration?
Background:
2023-07-27 5:01 AM
2023-07-27 3:39 AM
Hello @Syn_BE
First let me thank you for posting.
It is not possible to add comments and notes to the device used in Cube Mx.
I recommend you take into consideration that you are able to notice the description, the summary and the documentation of each peripheral when you move the mouse cursor over the name.
2023-07-27 4:29 AM
Dear Mahmoud,
thanks for your answer. Yes, I know the possibility to see "summary, etc" by "mouse over". And that's really a good feature.
But the big advantage of writing own comments would be "documentation for others": You could tell other project-people what you use the timer (the peripheral) for and why you had to configure it that way.
Maybe this would be a useful feature request?
2023-07-27 5:01 AM
2023-07-27 8:12 AM
Dear Pavel,
good link! Thanks a lot. I will add my feature requests there.
