CubeMX 4.14 ignores Keil additional targets for compiling
taraben
Posted on March 28, 2016 at 13:40
I use additional targets for tweaking compiling at different stages of the project:
- move in memory
- set Vector table offset
- compiler defines
- user defines to create bin files
I use stm32f437
Now when I recreate the project from CubeMX targets getting lost.
Pls fix this bug.
Regards, Adib.
#stm32-keil-cubemx
Nesrine M_O
Lead II
Posted on March 28, 2016 at 19:06
Hi Adib,
Thank you for your feedback. The issue has been reported internally.
-Syrine-
stm32cube-t
Posted on April 12, 2016 at 16:19
Dear user,
Can you please detail where your customizations take place within the IDE and for which parameters:
- project target options
- project group changes :  adding a group, adding a new/existing file, group option configurations.
thank you
taraben
Posted on April 23, 2016 at 22:26
I do modify usually;
in the dialog ''manage Project items'':
- ADD Project Targets
- ADD Groups
In the dialog ''Options for target'':
- Tab ''Target''change memory settings, IROM addresses
- Tab ''Output'' change output directory and name of executable
-Tab ''User'' add custom command
- Tab ''C/C++'' add include path, add defines, change other compiler settings
- Tab ''Linker'' specify different scatter file
Regards, Adib.
