compilation failed with cubemx generated code when configuring i2c interface in smbus mode
Antoine1
I'm trying to configure an I2C interface in SMBUS mode on an STM32F4. However, cubemx (v5.3.0) does not correctly generate code (missing include and file about HAL SMBUS, missing handle, empty init function, etc.). Compilation failed.
Is there a plan to fix it?
Antoine1
Fixed in cubemx v5.4.0
Thank you
4 REPLIES 4
Hello @Antoine​
Could you please send me your .ioc file to check the problem.
Nesrine
Antoine1
Hi Nesrine,
Please find attached .ioc file.
Antoine
Hello @Antoine​
Thanks for the feedback,
It will be fixed next cubeMX version.
Best regards,
Nesrine
Antoine1
Thank you
