2020-12-15 4:46 AM
static void MX_RTC_Init(void)
/* USER CODE BEGIN RTC_Init 0 */
/* USER CODE END RTC_Init 0 */
LL_RTC_InitTypeDef RTC_InitStruct = {0};
LL_RTC_TimeTypeDef RTC_TimeStruct = {0};
LL_RTC_DateTypeDef RTC_DateStruct = {0};
/* Peripheral clock enable */
LL_RCC_EnableRTC();
/* USER CODE BEGIN RTC_Init 1 */
/* USER CODE END RTC_Init 1 */
/** Initialize RTC and set the Time and Date
RTC_InitStruct.HourFormat = LL_RTC_HOURFORMAT_24HOUR;
RTC_InitStruct.AsynchPrescaler = 36;
RTC_InitStruct.SynchPrescaler = 999;
LL_RTC_Init(RTC, &RTC_InitStruct);
RTC_TimeStruct.Hours = 15;
RTC_TimeStruct.Minutes = 19;
RTC_TimeStruct.Seconds = 0;
LL_RTC_TIME_Init(RTC, LL_RTC_FORMAT_BCD, &RTC_TimeStruct);
RTC_DateStruct.WeekDay = LL_RTC_WEEKDAY_MONDAY;
RTC_DateStruct.Month = LL_RTC_MONTH_JANUARY;
RTC_DateStruct.Year = 20;
//RTC_DateStruct.Day = 15;
LL_RTC_DATE_Init(RTC, LL_RTC_FORMAT_BCD, &RTC_DateStruct);
/* USER CODE BEGIN RTC_Init 2 */
/* USER CODE END RTC_Init 2 */
}RTC_DateStruct.Day = 0; line is lost.Cube doesnt generate this line.
2020-12-16 12:44 AM
Dear @Community member ,
Thank you for your feedback.
This was internally checked and it will be fixed as soon as possible.
Thank you !
2020-12-15 4:50 AM
Hi @Community member ,
Could you share you .ioc file?
Houssem
2020-12-15 5:36 AM
2020-12-16 12:44 AM
Thank you !
2020-12-16 12:58 AM
By the way,low layer library gettin bcd result doesnt work ,still produce binary result.This takes time almost half day to realise it.
