2026-03-24 7:10 AM
I found an issue when generating code for a BLE application with STM32CubeMX v6.17.0.
In particular, I have a service called DataTransferService with three characteristics:
The DataStream characteristic is configured as a notification with a fixed value length of 100 bytes.
When I try to increase its length up to 250 bytes and regenerate the code, the following functions in custom_app.c are removed:
I have attached the .ioc file for reference.
2026-03-30 4:44 AM
Hello @DecaMeron
Thank you for bringing this issue to our attention.
Issue has been escalated to dev team under internal ticket ID #0061145
I will keep you posted with updates.
THX
Ghofrane
2026-03-24 7:35 AM
Hello @DecaMeron
I'm currently checking this behavior. I will get back to you ASAP.
THX
Ghofrane
2026-03-30 4:44 AM
Hello @DecaMeron
THX
Ghofrane
