2024-04-29 01:00 AM - edited 2024-04-29 06:21 AM
I use CubeMonitor V1.8.0 with my STM32G474QET device. Unfortunately the chart inside the dashboard is very small so I can`t work with it. Is there any possibility to set the size of the graph? The only thing I found is the duration in seconds, but that only changes the resolution but not the chart size itself.
Thanks for any recomendations.
Benedikt
2024-05-02 05:36 AM
Hello @berait
You can configure the chart size in you flow while editing the node
2024-05-02 05:36 AM
Hello @berait
2024-05-06 11:29 PM
Hi Richard,
I somehow have not seen this setting, thank you for your hint
regards, Benedikt
