Missing acquisition nodes on macOS
Jabub
Today I tried using STM32CubeMonitor 1.7.0 on macOS Sonoma (MacBook with M1 chip), but after installing the app opens without acq in and acq out nodes in the library, and of course it complains about missing node types when loading sample Basic_Flow (see attached screenshot).
I tested it on another MacBook, with same results, and downloaded an older version (1.6.0), still with the same outcome. Windows version works fine out of the box, but my whole workflow is on a mac.
Is there anything obvious I am doing wrong?
Thanks,
Jakub
stephane.legargeant
Hello @Jabub
I suspect a library removed in Sonoma. Can you try to install the ST-Link server and let us know if it is better ?
https://www.st.com/en/development-tools/st-link-server.html
Thank you
stephane.legargeant
Hello @Jabub
Thank you
Hello @stephane.legargeant
That helped instantly, thanks a lot!
