STM32CubeMonitor (MCUs)
Ask questions on STM32CubeMonitor. Discuss the latest updates, including specialized versions (power, RF, USB-PD).
STM32CubeMonitor-1.12.0 is available
Hello The version 1.12.0 of STM32CubeMonitor is available on st.com :  https://www.st.com/en/development-tools/stm32cubemonitor.html What are the main changes in this version ? Node-RED® updated to version 4.1.3.STM32 devices list updated.Software de...
STM32CubeMonitor-RF V2.19.0 is available
Hello A new release of STM32CubeMonitor-RF is available on st.com. Click on "Get latest" to download the version 2.19.0. What are the main changes in this version ? Alignment with STM32CubeWB firmware 1.24.0.Alignment with STM32CubeWBA firmware 1.8.0...
Resolved! [Solved] Reset a variable at fixed frequency
Hi all,I have a data streaming firmware and to keep the stream alive I must reset a counter before it reaches a fixed value.Is there a way to perform this operation with CubeMonitor while monitoring other values?Thank youWalter
Myzhar by Associate III
  • 4123 Views
  • 9 replies
Resolved! [Solved] "Single value" subflow not working
Hi,I'm trying to plot different values on different plot charts because they live in a very different scale, but it seems that the "Single value" subplot is not working.If I remove it the plot charts show all the values correctly.Any idea?Thank youWa...
  • 2774 Views
  • 6 replies
Resolved! Additional Node support
Hello, I wondered if you will add the ability to import/add new nodes to the STM32CubeMonitor system from the Node Red Library (https://flows.nodered.org/)?After all this is one of the strengths of the Node Red system to enable the use of collabrati...
Resolved! Single Value / Filter subflow module use
Hey allI've been having issues filtering out values from my processing module1) for the second graph and gauge i went in and modified it to look like thisi wanted to extract a variable out of my list called sum so in the varfilter i placed sum as a s...
AMeta by Associate II
  • 1799 Views
