XPSR register bitfields?
Options
‎2023-09-02 8:23 AM
Is there a way to split the XPSR register view up so you can see each status bit by its name rather than the 32-bit value?
The SFRs have this feature, why do the general registers not have it enabled by default?
11 REPLIES 11
Options
‎2025-03-02 9:46 AM
Hi Glenn,
This work-around could be helpful?
Options
‎2025-03-02 1:27 PM
Interesting idea. I might try setting that up for next year's class.
Thank you!
- « Previous
- 1
- 2
- Next »
