2025-03-06 2:28 AM
I have a c++ file with a table of utf16 c style strings encoded as utf16. I need this file to be encoded as utf16 for the compiler to understand correctly the 'special' characters. In IAR, it was super easy as the compiler could read both utf8 and utf16 files.
It seems however that cubeIDE only handles utf8 encoding. Is that true? Is there a work around? Moving my table from utf16 to utf8 would really annoy me…
Thanks in advance
2025-03-06 4:21 AM
Please have a look at this thread, maybe you will find a suitable code page.
Good luck!
/Peter
2025-03-06 4:21 AM
Good luck!
/Peter
