2024-08-10 02:17 AM - edited 2024-08-10 02:19 AM
I want to use the FPU in an ISR. Will I have context switching issues or i have to specifically make changes in the System_stmxx.c if i am using code generated from CubeIDE.
Do i need to setup these registers explicitly or it is handled by CubeIDE by default? (i didn't found these bits explicitly setup in System_stmxxx.c )
